dies when i put in gear
allen6634
i have a 1983 johnson outboard it is a 88spl the engine runs great ,but it will not idel when i put it in gear. i have been adjusting the throttle cable to make it stay running ,but it slams real hard in gear i realy would like to fix this before i break something. please help?
86 century
Ensign
Re: dies when i put in gear
Are you setting it in the water or on the muffs.
allen6634
thits is when i am on the water ,i haven't tryed it on muffs.
Larry Tate
low speed idle circuit? coil(s) shorting out under a load? you might be in for it with this one...i would first try idling it in gear on muffs. that may give you some more direction as to where the problem is.
boobie
What's the compresion on it ? Will the spark jump a 7/16 " open air gap on a spark tester ? Running on muffs just tells you it's running. In the water you have the proper back pressure in the exhaust system.
