bob johnson
- Joined
- Feb 25, 2009
- 4,306
1997 Johnson FAST STRIKE 175 hp power head on a 1996 ocean runner midsection. installed 2 years ago...been running well since...second to the last trip out I noticed a cough and a sputter once in a while...so before the very last trip I pulled the plugs...they looked find a very light caramel stain o the porcelain... no carbon or buildup... I checked the spark.. all 6 jumping 1/2". ran a spray can of carbon free from sierra.... and I took her out the next day... she starts right away but she hesitated and stumbled when I put her in gear.... I had to throttle up fast to keep her from dying. this went on for the next hour or so when ever we stopped to try and get bait. a few times in reverse it died right out.... it just didn't like that low rpm in gear.... in neutral she seemed to idle fine.... I had noticed she burned rich last fall... and I truned in the idle screws... 1 whole turn...to see if that helped.... I think it did a LITTLE.... the last trip out it was too rough to go WOT...but she ran perfect at 4000 rpm....... for a good 1/2 hour run at one point. Im thinking idle passages maybe...but before I spent the cash on carb kits for SIX carbs...I figured id ask if its possibly something else.... the roller on the throttle linkage is in excellent shape..i know they can crack and fall off, then the throttle does nothing until you get further along...... maybe its an RPM setting thing with the LynK and sync.....
thanks
bob
thanks
bob
