diesel batteries
WIMUSKY
A guy I know has a '08 diesel Ram. He thinks his alternator is shot. Both batteries are reading 11.7v and of course won't start. If he gets it started, will it run off the batteries, or can he drive it and just not shut it off...... I have my thoughts...
Thanks...
Grub54891
Old school diesels didn't need a battery once running. If it's controlled by a computer now, it will need fully charged, good batteries if the alternator in not working. It will only run till the batteries won't supply enough voltage/ amps to run the computer.
WIMUSKY
That was my thought. I'm guessing an '08 is new school? I'm thinking that goes w/o saying...
Thanks Grub
12 volts is fully discharged, 11.7 volts is a dead battery. 13.4 volts is a freshly charged battery
This was going on with my 08 last year and nephew's 07 the year before. The truck as one shorted cell battery. Disconnect one of the bats and measure each. Replaced my bats with Duracell at Sams
WIMUSKY
That always amazed me that it doesn't take much of a voltage drop to not turnover the engine...
WIMUSKY
I sent the guy the info. He already has a guy coming up from his hometown with a trailer, 3hrs away.:facepalm:. If I would have known earlier we could have checked the output of the alt and determined if was the bats or the alt. Owell...
MTboatguy
An '08 needs fully charged batteries to run, it is amazing how little it takes in voltage/amp drop will kill them.
WIMUSKY
He charged the bats. One was over 13v, the other 12 something. Could be a bad one. Its on a trailer heading south...
It will run fine with just one bat, so long as the Pos doesn't contact ground
WIMUSKY
Seems the good bat wasnt the primary. It was on the drivers side. I believe the primary is the passenger side.
I know nothing about diesels except I would like a newer dually...
There is no primary or secondary, they are both in parallel (12V and more amps). Only time they could use 2 bats is on real cold days using the grid heater to warm the air before cranking
