Difference between a 3 and 4 blade prop
parrilladk
Is the same pitch prop in 3 blade have the same rpm's that a 4 blade prop? Assuming same manufacturer.
Thanks,
Dave
JUSTINTIME
Re: Difference between a 3 and 4 blade prop
u usally lose 100-150 rpm form a 3 to 4 because of more grip
Dhadley
There's a lot more to it. First keep in mind that generally speaking - very generally - a 4 blade runs at a higher X dimension than a 3 blade. And that's if you're comparing the same manufacturer and style. So that brings you to the next question - are you talking about an outboard or an I/O? It's a lot easier to raise the height on an outboard than an I/O.
If you're talking about an I/O there are 4 blade props made specifically to run deeper in the water.
Props have different lift abilities. If you're running a 3 blade with built in bow lift, and that's what your boat needs, you don't want to replace it with a 3 or 4 blade that has tail lift.
Again speaking generally, if you replace a 3 blade prop with a 4 blade of the same make and style it'll run a little higher X dimension. That should put the rpm back where it should be (assuming the 3 blade set up was correct) and give you everything the 4 blade is supposed to do.
parrilladk
The prop is for an outboard Johnson 115hp (2000) on a mako 171 ('89) that is currently turning 5900 rpm with a cavitated old 13 1/4" x 15" prop. Considering a solas rubex 4 blade 12.75" x 17" or a solas rubex 3 blade 13.25" x 17". Thanks for the previous replies, tons of info on these forums.
Dhadley
That's the center console model, right?
If you don't have a jackplate I'd take a look at the Stiletto line. The Advantage series is a pretty darn good prop and is available at iboats too.
parrilladk
Yes, center console. No jackplate.
