FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
So im getting ready to slap a new prop on my alpha one drive and i see in the parts breakdown that there are 2 different thrust hubs depending on what generation of prop you use. How can you tell which one you need?
most newer style use the thinner thrust hub. some old props like Michigan use the thick one..
Should you guess wrong, when you tighten the nut you will jam the prop against the case, you needed the thick thrust hub .If you tighten the nut and the prop is not seated all the way ,you need the thinner one
