So as you some of you guys know the 86 stingray I picked up which the PO thought was winterized wasnt. It has a 2.5 which I believe is the original motor. As soon as I got it fired up after dumping a few bucks into it I noticed a waterfall of fresh water coming from the side of the block behind the manifold, which im told is a common crack prone area for non winterized boats.
Anyways im considering doing an engine swap as the rest of the boat is in decent shape. Wondering about a few things...
What should I expect to pay roughly for a used 2.5 or 3.0 im in Connecticut if it matters?
My engine is a 86 I realize finding a 80's 3.0 might make life easy but there seems to be more "newer" 3.0s out there for sale. It looks like the ignition setup is different on newer 3.0s. How complicated is it to get a newer 3.0 running on a mid 80's 2.5 boat with the wiring? Are there any mechanical differences? I know my outdrive is a alpha 1 gen 1 so would that cause any issues?
If I find a motor should I be concerned with checking or replacing anything on the engine while its out? Trying to think ahead of extra parts or components I will need.
Any good I/O engine removal and install DIYs out there you guys can recommend?
