Flynny
- Joined
- Jul 22, 2011
- 86
I bought a used '95 70HP Johnson and an '89 Sea Ray 160 about 6 years ago, and had a mechanic set the engine up with the boat. I finally got around to hooking up the tachometer today and took it out for a spin. At WOT, I only reached 5000 RPM. I understand that optimally it should be running at around 5500RPM at WOT. Is it worth buying a new prop to correct this?
The boat is a little less than 17 feet long, and had about 450 pounds of passengers and equipment on board. The current prop is aluminum with a 14in diameter. How do I find the pitch of it (if you need that)?
How much would a stainless prop improve the hole shot? It's pretty good now, but I'm always up for more performance.
