Difficult Fault codes
mundyj
Need assistance - still trying to track down my issue on my 2016 Monterey 218SS with a 5.3L V8-300C that can't start. It relates to three active SPNs 697/698/699 - each showing an FMI 5. The issue is described as an Auxiliary Pulse Width Modulation Analog Display Driver(s) 1, 2, 3 having low current or being open. The codes get generated with the key being turned on - without cranking the engine. (see pics)
Working through fixing this, I've done all the standard things and am currently focused on the Engine Protection System - the workshop manual indicates that the oil pressure, throttle control, and MAP feed it. The oil pressure and throttle control appear good.
My question to you experts is when I pulled off the TMAP sensor input, I only got an SPN 105 FMI3 (Intake Air Temp shorted high) error code. It is a dual pressure/temperature sensor (Volvo Penta 3859020) but is this normal to only see the one (temp) error get logged?
Open to any advice!! Thanks!
John
muc
"Retired" Association of Marine Technicians...
Would need a serial number. Pic doesn’t look like a 5.3
