gomopar440
Thread starter- Joined
- Nov 27, 2007
- 281
Long story, summed up. Still working on the tow rig, mostly because I'm now converting it to EFI using a MegaSquirt 3/3X ECU kit to allow me to run it in full sequential fuel and spark mode. It's also getting a full roller cam and valve train setup to get away from the older flat tappet technology. At least that WAS the plan... I have since found another boat project, so I'll be holding off with the EFI swap and sticking with the carb setup for a little while longer. The cam and valve train swap is still happening though.
The new project is a 1971 Pony V-hull speedboat I just picked up from an ad on Craig's List. It will be commandeering the '84 Mercury 115, so the Laker project is getting mothballed for a while. Since I pulled it home yesterday, I stripped the few remaining components from inside the hull. There's an old style Airtex electric fuel pump (model# 12V-E12AX) and a Mercury fuel filter base (model# 89876) that look good enough to reuse. The steering is a vintage rack style setup with a single 13' Morse cable. That is getting replaced with a Teleflex NFB 4.2 Rotary dual cable kit to prevent high speed flutter in the steering. Other than that I'm going to try to keep it simple so I can hopefully get it on the water this summer. Here's some pics from the CL ad.
