Hi All
Sad to say I made no progress.
I have a mechanic two doors down, had him stop by just so I could have some strong hands and a mechanical mind set take a look
Together we can easily man handle the engine.
Summary: We moved the engine (via front mount adjustments) all the way from absolute high right. to absolute low left. We left the dowel in so we can see the imact and it was very significant to watch, it's pretty cool to see the dowel's positioning radically change.
The telling point: the alignment bar hits the coupler in the same spot at highest right and lowest left. and any point in between
I'm not sure how much the gimbal should swivel but my "bumps" to the bar were certainly hard enough to convince it to swivel though it moved only a fraction.
So,
1) I 'borqed' up the gimbal installation. Hard to swallow for me as it only goes in one way...and the 1" dowel shows us the alignment into the coupler through the bearing through a variety of motions. The lack of swivel of the bearing has me concerned I damaged it on the insert
2) I've got bigger problems. Complete movement of the front through a variety of directions with no change on the alignment bar.. that tells me the REAR needs to go up about 1/4 - 1/6" and right about 1/6" - I read the service manual, I understand that there should't be adjustments to the rear.. However there ARE mechanical components and hardware involved in the rear mounts, to me it's quite possible they've been compromised especially considering the boat came off the trailer on the highway some time back...
Unfortunately it's time to let a marina look at it. My pride hurts a lot.. and my wallet may hurt a little too. But I'm at the point now where I need the experts to tell me what exactly happened here.
I have no doubt that if my alignment bar made it into the coupler AT ALL, I'd be finished by now. but this circumstance has me stuck.
boooo.
-Pantz.
I'll keep posting if anyone cares at this point.. but it's going to be a while to get the marina to look it over
