chiefcatchemall
Thread starter- Joined
- Jul 24, 2009
- 197
Re: Dirty Cyls 73 20 hp johnson
okay guys thanks
okay guys thanks
" Valve on the tank"? are you refering to the vent screw ? that should be open when you run the motor.float sets parallel with the bottom of the float bowl...Next thing I am going to try is leaving the valve
When you squeeze the primer bulb it should get firm and not allow further squeezing.Normal for the bulb ro be lass firm as you use fuel.
on the gas tank open, setting my low speed needle 1 1/2 turns out, and trying to find the exact plugs they call for...As of right now I am waiting on a fuel pump rebuild kit and the two coils that set on the outside of the motor...
Have you tried unhooking the gas line when starting? Prime the carb and unhook the line,see if it will start.
As far as starting; any non resistor plug with the right reach would start it.The J4C will work fine.And champion are suggested.
When its tight its vacuumed but when I back of it a quarter turn it releases all the pressure the tank builds.... then if I back the cap off another quarter of a turn the cap is ready to come off...Its an older tank...
