Disable oil alarm in TKS system Sportjet 175
basilfaulty
Does anyone know how to disable to oil alarm portion of the TKS system. I want to retain all other features and just disable the oil alarm only. I am going to run premix and don't need the oil alarm. I did an exhaustive search and couldn't find a conclusive answer.
basilfaulty
Re: Disable oil alarm in TKS system Sportjet 175
ok, how about I do this.....leave all of the TKS system in tact including the oil alarm and disconnect the wire at the warning horn, then run a new wire to the horn from the temp senders. This should give me an overheat alarm...right. Will the TKS put the engine into limp mode or anything because it thinks there is no oil? Again I would like to retain all functionality of the TKS except for the oil alarm.
Robot1947
You need the alarm system to warn you of overheat. Disabling the oil injection system is technically against the law as it increases pollution. Go to www.marinesolutionswi.com and check out their Electronic Oil Injection systems.
