dockwrecker
- Joined
- Mar 10, 2006
- 1,392
I apologize for digging this up for the umteenth time, yes I've read all the threads but I'm not seeing what I'm looking for. My drum system is junk and I'm going disc. I'm having difficulty figuring out which Kodiak retro to buy. I see a note on the Champion Trailer site that for GVWR's over 3000# that I should install brakes on my second axle as well as replace the drum system. Since my trailer (built for my boat) only came with a single axle drum system (and DOT certified for the GVWR), do I really have to do this? I'm expecting increased braking not less going to discs so this seems odd. Trailer and boat are approximately 6200# ready to go. I'm also concerned that if I add the additional calipers that the master cylinder is up for the volume or is there some kind of proportioning/balance valve needed. I'm adding the back up bleed off solenoid when I do this also. Anyone else using single axle brakes on a tandem setup at this load with Kodiaks? I'm a fresh water boater and I also question the whole stainless route for what I do. Experience PLEASE!
