made in china
- Joined
- Aug 19, 2009
- 51
On my 1986 Larson, the gauges are from when the boat originally had a 1986 Mercury 150 OB. The prev owner removed the 150 and installed the current 1990 Mercury 115. The 150 must have been a nicer package because it seems to have had some gauges that the 115 does not support.
Currently my dash has gauges for trim, temp, tach, speed and fuel level. Except the fuel gauge, they all appear to be original equipment Quicksilver gauges.
Only the tach and fuel level work.
The trim gauge doesn't work because the 115 I have doesn't have the option for a trim sender, as far as I can tell (it's a single ram trim). So, this gauge may need to be replaced with something else.
The Temp gauge is also inop. As far as I can tell, my motor does not currently have a temp sender on it. Is it possible to install a Mercury OEM temp sender somewhere on this motor? I have been unable to track down if it is just a simple sender that is installed where a plug may be now.
Speedometer is not working because the tubing keeps getting cut by the transom mount. Does anyone know the proper way to route the tubing down to the pitot pickup to prevent it from being cut every time the motor is raised? Is it routed externally or internally? I can't find a way to route it that it won't get cut! Also, do I need to use stiff plastic tubing to keep the MPH indication reliable?
I can see I'll probably end up replacing the trim gauge with a voltmeter.
I'd like to keep the water temp gauge, does anyone know what my options are?
Regarding the trim sender, am I correct that it's not an option for my motor setup?
Thanks for the help!
