Disconnecting "syringe primer" 1986 8HP BE8BACDE.
cprodave
I am trying to remove the Powerhead but first need to disconnect this Choke linkage , etc. I have removed the slot head Set Screw but linkage doesn't slide apart as I would have expected. I don't want to use too much force as this might damage the internals of the (not used for many Model Years) "syringe primer" that was part of the Choke setup.
Doe the Choke Knob unscrew off, or is there some other trick I'm not following? thanks for any help.
