Leardriver
- Joined
- Oct 7, 2008
- 382
Hi all!
I am cleaning up a boat with a Bravo Three that seems to use gear lube. It is an '02, drive serial 0m1444xx, with less than 150 hours on it. It went through half a reservoir full in 5 hours of use.
It does not seem to have water in the lower unit, tested by removing the lower drain plug on the drive. The plastic reservoir inside the engine compartment does not have water in it. The bilge is spotless, certainly no sign of leaky lines.
I've heard about this before, and just can't find the threads. Is there an internal seal that goes bad, and spits the lube out into the water? How to test or verify? Cost to repair?
Thanks as always for your suggestions.
