Redrig
Thread starter- Joined
- Oct 13, 2009
- 873
Hello all,
I have my steering removed from my boat . It is not a standard system, its an old OMC thru hull that uses that bronze ball and clam shells where it enters through the transom.
I have the cable out to replace the seal in the clam shell and I would like to inspect it further while I have it out to make sure the inner cable is in good shape. Here is where I am hung up .
There is some type of crimp on the rod (helm end) that I can not figure out how to remove , I can just simply cut the crimp off and have something fabbed up in its place afterward , it appears to be some type of swage crimp.
Ideally I would like to grease the entire cable once I have it apart , and make sure it is sound.
are there any tricks to remove this crimp ? How should I proceed ?
I cant get pics to load otherwise I would post up my cable , the ideabook keeps timing out.
before I get flamed too hard about just buying a new cable , they haven't been made in 30 years and I can not locate a new one.
this is the steering type I have. Thanks in advance for your thoughts
https://www.crowleymarine.com/johnso...arts/41572.cfm
