Distance from lower gear case to prop
Chris1956
So you are talking about a Johnnyrude thru the hub exhaust-style prop?
The thrust washer keeps the prop from hitting the gearcase.
The hub of the prop usually fits into the hub of the gearcase, with a tolerance of 1/8" of so.
Is that what you are asking?
Yes I found a SS prop a quick silver in the back with the correct spline but it has 1" of stand off to the gear case. I know its not correct but all we do is jug fish out of this boat. Not looking for speed or power just chase a few jugs down. I think it will cavitate from the exhaust and yes it is exhaust through prop set up.
