andrewterri
Thread starter- Joined
- Jun 25, 2014
- 437
I think I am having an advance problem. The engine is an 89 mercruiser 3.0. I set the timing and the engine runs smooth when in gear, however it shakes in neutral still. My other problem is when I adjusted my throttle cable to put slight pressure on the cable to take up the slack because my idle was to high the boat will not start. I have to pump gas in through the accelerator pump to get it running and it is barley running for about 15 seconds then runs fine. I was thinking it is the distributor not advancing correctly. What do you guys think? I am going back to the lake today and was going to set the timing again while in neutral using the light with the help of a friend and see of that helps the shaking but not sure what to do about the starting cold issue. Thank you in advance...
