DISTRIBUTION BELT HONDA 75
DELFO
HELLO, I NEED INSTRUCTION TO CHANGE THE DISTRIBUTION BELT FOR HONDA 75 HP.<br />THANK YOU
JB
Re: DISTRIBUTION BELT HONDA 75
Hello, Delfo.<br /><br />You need a Service Manual to instruct you on changing the camshaft drive belt. If you get it wrong you could destroy your engine.<br /><br />Good luck. :)
DELFO
Thank JB for the replay, in Italy is very hard buy the Service Manual for my motor.<br />You know same web site that give information or drawing for this maintenance operation???<br />By By
JB
Hi, Delfo.<br /><br />We do have a Honda expert member. Perhaps he will come along and offer more help.<br /><br />Good luck. :)
P.V.
I'll try. 1 st, why are you changing the belt ??? They are generally considered a non-wear item. I don't believe Honda recommends you change it at any particular hour interval. So, unless it's damaged, why ??? <br />But, heres how. Take the 3 10 mm screws off that hold the recoil starter on. On the aft "tower" (thats what I'll call the support pieces that the 3 screws went in), it has a "mark" on it. That is the TDC mark, top dead center for the piston. So turn the flywheel clockwise untill you see the "T" mark on the flywheel align up with that "mark" on the aft starter recoil screw "tower". Hint, if you had the spark plugs out, you could check that the pistons is at max. travel out. You may also note that the flywheel also has a "F" just next to the "T", that's at the point where the ignition spark fires when adjusting the breaker points or aligning the electronic sensor for the ignition. depending on if you have the older or newer ignition. So, again, the flywheel has a "T" for top dead center and a "F" for "Fire". Anyway,now that you have the pistons at "TDC", remove the belt, look exactly down above the camshaft. there is a slight impression, a "HOLE", about a pencil dot in size, just "forward towards the split line almost at the head gasket.It's on the cylinder head !! See it ??? That's what you align the "dot" on the camshaft pully with. Match the "dot to dot"!! Reinstall the belt, it should almost slip on. You usually have to turn the flywheel to get it on. Turn over the motor by hand and check the alignment. Mark on the flywheel to mark on starter boss and mark on cylinder head to mark on camshaft sprocket. Hope this helps !! How's things in Italia???
DELFO
Thank P.V. for the explanation, but my english in not very good, i not understand all.<br />Can you send me some page or drawing by e-mail at the following address:<br />DELFO100@HOTMAIL.COM <br />If you can't no problem !!!<br />Thank you for all , and one greeting from Italy.<br />ByBy
DELFO
For PV: i have three "T": 1 mark on the flywheel, 1 mark on the camshaft pulley, 1 mark in the plastic carter side down.<br />If i align all T is right ????? <br />By
P.V.
Well, let's see ! Flywheel should have a "T" ,right next to a "F". Align the "T" with the "post" of the rear support (for the aft recoil bolt). Dot on the cam pully should just be "over"- -- aligned with the "dot" ontop of the cylinder head, just towards the "front" of the cylinder head. Look down from above. It's right below from an overhead view! I'm not sure what you mean by the "plastic carter side down" ???? Sorry, don't have the ability (skill) to send you a picture....
DELFO
All the components of the distribution ( flywheel, belt, pully) are closed in two carter made in black plastic .<br />My Honda is BF 75A year 1996.<br />In the middle of the down carter is mark one arrow with T, is between the fly and pulley<br />ByBy
