Distributor Advance issue?
Bedrest2
Hi all; Have an issue with timing, Volva Pent 2.1 AQ125B, New plugs,Oil, and
Electronic modual, replacing the points, rebuil carb. 800 rpm, 6 btdc. When
at crusing speed, 3100rpm, 40-45 btdc, can't really tell, scale not that far.
Do I need to replace distributor, or do I have a timing belt issue, can not see
timing marks on pully's, cooling system in the way (closed system).
First time I/O owner, and not a mechanic, looking for help. Cleaned distributor
when I had it out for modual replacement, could I have done something to
make it advance to much? Or could the springs get weak and allow for to
much advance. Thanks in advance.
Don S
Re: Distributor Advance issue?
You need to get an advance timing light to check the advance timing. It should be 32-35? BTDC at 4200 rpm.
There are 2 springs under the points plate in the distributor. Are they both ok and hooked up?
Bedrest2
Thanks for the reply Don S.
Yes, springs intack and hooked up, look OK, but I'm no machanic, looked
at when I replaced the points with a Hot Spark Modual, Dist. was on bench
when done, but never put on a test bench. I'm Electrical controlls Engineer by trade. I take it an Advance Timing light is not the same as a regular
automotive Timing light?
Found the timing light info on the web, I believe it's correct. I think I will
have to work on carb adjustment now, one last trip for the year today.
Getting time for storage around here. Thanks for the knowledge.
