Distributor cap screws
metsfan3197843
Misplaced the 2 screws that hold down the distributor cap. T-20 torx head mercy part number 10-884786. Can’t seem to find any info on what thread pitch they are so I can buy a couple new ones. Anybody know??
There metric, and right now don't remember the number. If one ever gets stripped out, get the next size up and re-tap. This is what I did on mine
Ayuh,..... Anytime I lost 'em, I figured it's time for a new cap, that comes with new screws,.....
metsfan3197843
Yeah I tried that route but when you live on an island in the middle of nowhere, parts are hard to find.....unless you own an outboard then everyone in town carries parts😡
metsfan3197843
Thanks for the help guys. After tearing apart the garage I finally found them. Always the last place you look😜😁
Fun Times
:thumb:Was curious to know the size in case metsfan3197843 or someone else ever needed it so I went looking and see GM recommends the same idea as they have a few sizes/part numbers shown for trucks that used the same cap design back in 1998...Trying a copy and paste of the info provided below the GM link as I'm not sure if the link would go down after awhile.
https://www.gmpartsgiant.com/parts-list/1998-gmc-c1500/distributor-ignition.html
BOLT, Distributor Cap Retaining Select vehicle options to narrow down result
  • resource
    10457666
    BOLT, DISTRIBUTOR CAP(20 MM LG, W/SCOTCH GRIP, OVERSIZED)(PART OF 1)
    10457666
    Fitting Vehicle Options:CK1(L35)
    Require Quantity:02
    Package Quantity:1
    $8.16
    $4.50
  • resource
    10457666
    BOLT, DISTRIBUTOR CAP(20 MM LG, W/SCOTCH GRIP, OVERSIZED)(PART OF 1)(USED TO SERVICE 10475922 IF THIS HAS BEEN REMOVED SEVERAL TIMES AND CANNOT OBTAIN PROPER TORQUE)
    10457666
    Fitting Vehicle Options:CK1,2,3(L31), CK1,2(L30)
    Require Quantity:02
    Package Quantity:1
    $8.16
    $4.50
  • resource
    10475922
    BOLT, DISTRIBUTOR CAP(M4 X 1 X 13.4, 12.6 THREAD)(PART OF 1)(9.2 OUTSIDE DIAMETER,410 STAINLESS STEEL,GM1000M,TORQUE,MACHINE)
    10475922
    Fitting Vehicle Options:CK1(L35), CK1,2(L30), CK1,2,3(L31)
    Require Quantity:02
    Package Quantity:10
    $1.65
    $0.90
  • BOLT, Distributor Shaft Select vehicle options to narrow down result
  • resource
    10457666
    BOLT, DISTRIBUTOR HALL EFFECT SWITCH(20 MM LG, W/SCOTCH GRIP, OVERSIZED)(PART OF 1)(2.368)(USED TO SERVICE 10475922 IF THIS HAS BEEN REMOVED SEVERAL TIMES AND CANNOT OBTAIN PROPER TORQUE)
    10457666
    Require Quantity:02
    Package Quantity:1
    $8.16
    $4.50
  • resource
    10475922
    BOLT, DISTRIBUTOR HALL EFFECT SWITCH(M4 X 1 X 13.4, 12.6 THREAD)(PART OF 1)(9.2 OUTSIDE DIAMETER,410 STAINLESS STEEL,GM1000M,TORQUE,MACHINE)(2.368)
    10475922
    Require Quantity:02
    Package Quantity:10
