Distributor shaft
further
Guys,
While I'm replacing the manifolds and risers and fixing my leaky oil pan, I'm changing out the plugs, wires, cap and rotor. I pulled the cap off and after fighting with it for some time I decided to man up, grab it with two hands and pull with all my might. Well, that worked :)... It was pretty well corroded on there but came off.... The shaft is pretty rusty....
Any recommendations on how to clean the shaft up and should I put some grease on it before installing the new rotor?
Re: Distributor shaft
Guys,
Ayuh,.... I can't see it from here, but I've had good luck usin' Fluid Film,....
A green scrubby pad for the tough stuff,...
A rag, if it ain't to bad,...
