Dixie Craft Trailer
Ram58
A friend of mine has a 1987 single axle Dixie Craft Trailer. He's replacing the bearings, races and seals. The brgs are L44643, the races are L44610, and can't make out any numbers on the seals. Any idea what seal this takes. Also has 1 bad hub that needs replaced if anyone knows what hub to get. The axle is 1 inch diameter. Thanks
Jeep Man
Re: Dixie Craft Trailer
Take the old parts into the supply shop. They will match it up for you.
spktho
I just went through this last weekend. One auto parts store wouldn't or couldn't look up them up in the book. A lady at Kragen finally figured it out--they had a bearing book that showed trailers and based on the combination of bearings also has the seal number. Good luck, because it took me a while to get someone to actually take the time.
kamby
Hi
Check out etrailer.com i know they carry the bearing kit for the l44643 bearing, l44610 race and 34823 seal http://www.etrailer.com/p-BK1-100.htm
for the hub they sell them too, just got to make sure its the right spindle sizes and bolt count, 1 inch so its probably a 4 lug if the hub is bad do make sure the spindle is good and not warped. http://www.etrailer.com/p-34822BX.htm
the bearings kit only does one side, but since your ordering a new hub they come with bearings and seals already.
