One of the basic laws of physics is that if a force is applied to an object, it will move in the direction of that force unless some other force is pushing back. A 1,500 pound boat is being pulled toward the bottom of the lake by gravity. The only thing that keeps it from going to the bottom is the force of the water (called buoyancy) pushing back against it. If you add up all the small upward forces the water applies to the toons and everything else it touches, it will come to 1,500 pounds. But, as was mentioned above, the water also pushes sideways on the toons, and the deeper it is the harder it pushes. ... Think about it - if you get a leak an inch below the water line it will be noticeable but not too bad. If you get the same size leak a foot lower, water will gush in. So when you build your box shaped toon, imagine a thousand small wood working clamps placed all over the toon, trying to squeeze the sides inward, and the bottom up. That's why I and others here have suggested you will need bulkheads (braces) inside your toons to keep them from distorting or being crushed by the force of the water.
