Re: diy pylon....
Ive had a few PM's about the parts I used. I did keep the receipt to scan and post, but its misplaced somewhere.
Everything I bought was from lowes except for the wood, and the 1 blue rachet strap.
Floor Jack $~60
4 Eye Bolts $~15 ( If I were to build this again id use 3, 1 front, 1 top back for tow rope and 1 about 4 inches below the tow rope eye bolt and connect the 2 rear ratchet straps to just that one eyebolt)
1 Carabiner $~4 type piece to attach ski rope to eye bolt.
1 Pipe mount $~9 found in plumbing has 4 holes for bolts fits inside the floor jack PERFECTLY! Dont be afraid to test in store.
1 Pin $~2 with latch to attach 1st section of floor jack to base.
4 pack of red ratchet straps $~12 (only need 2) BONUS!
Cut a piece of wood to fit wherever you want the base to sit. I used 3/4" plywood. Mount the pipe mount to the base with 4 bolts. Drill a hole large enough in the pipe mount for the pin to slide through, do the same with the 1st section of floor jack. If you have help it will be much easier to set 1 section of floor jack onto the base, and drill through both at the same time. Then connect your top part of the floor jack with the included bolts. Then strap it up
Your done.
Setup takes me about 5 mins, tear down takes me about 2 mins. I plan to get a bow strap somewhere, sometime. But Ive been running it down the front of the bow now for a month, and everything works fine that way.
I also bought some pool noodles, cut a slit in them, and put them around the rear straps, because sometimes when the wind catches the strap just right, it vibrates like crazy. Pool noodles fixed that and actually made it look better.
