Re: Do both batteries charge with the motor on?
Silvertip,
The few factory parallel battery set-ups I have come across, have always been the same identical batteries wired in parallel, with the same load applied and charging circuit. ie the batteries are always close to the same charge. While I didn't own one of the GM trucks you describe, I believe that is what they had.
My main diesel experience comes from my 28hp 3cyl tractor. It has one large cca battery that is significantly larger than the one in my 350 Mercruiser. Most tractors I've seen have one large 12V battery, with two 6V in series, being the next common. Most of the time, that appears to have been done due to space reasons. I have not seen any parallel set-ups on them.
For most factory recreational runabout boats, they don?t come stock with a second battery or switch. This is usually an owner installed or maybe a dealer option. On the former, I doubt that the owner replaced with identical batteries. Along with possible battery difference, you are now combining two different charge state batteries to be charged together.
Lets say running on Bat1 you moored for most of the day with auto-bilge pump stuck running, and voltage dropped to 9V. It couldn?t turn the motor over to start. You switch to Bat2 but now you have flooded engine. You open the throttle and you eventually get it to start, but voltage has dropped to 11V. You are going for a short cruise and turn the switch to both. The combined voltage equals 10V. The alternator will put out the higher charging voltage and supply any available current to charge a 10V. In the process to get the lower battery (Bat1) to a full charge, doesn?t that expose Bat2 to an overcharging condition? I don?t think it is major but repeated times will lower the life of the battery.
Lets say bat1 didn't get to full charge and now you dock, and go chat with some people you haven?t seen since last season. Opps, forgot to go back in the engine compartment and take the switch out of both. Now you have a decent amount of current flow, while no one is present in boat. It is typically not fused either. More charge/discharge cycles, reducing battery life.
To me, Bat1, Bat2, Off settings are all pretty much idiot proof. Both can be problematic.
With over 40 years on a small lake, the people I have towed have had a dead battery from trying to start or just a motor that won?t start. Never had one from running the battery down on radio or other accessory. Most of the time it has been user error with flooding a hot engine. I still smelled the gas when I stopped to help. No way I am going to jump start these idiots. Most of them have to be reminded to turn the blower on! Sorry, only can offer you a slow tow on a long rope.
