minuteman62-64
Thread starter- Joined
- Apr 12, 2011
- 1,350
..... or will this one work? Motor is 1982 Mariner, 30 hp. See attached photo. Black connector is labled as for "Yamaha & Mercury, 1998 and newer style engines."
When hooked together, the black connector from the hose sits at a small angle (10 degrees?) to the base of the connector on the engine (again, see attached). The hose connector is furthest away from the base of the engine connector at the fuel inlet prong. It seems like the locking prong needs to be slightly larger diameter, or, that the spring that pushes against the fuel delivery prong is so strong it pushes the connector out at an angle.
Based on the recommendation of the nice lady at West Marine, I also brought home a connector that was labled as for Yamaha engines. Both receiving holes on that one were too small in diameter to receive the prongs on the engine. However, the lady at West did let me know that people sometimes take multiple connectors home and return the ones that don't fit, but sometimes in the wrong package - so I shouldn't count on the package lable as representing the actual contents.
I should add that the brass fitting is actually a tank fitting - but the black connector sits on the engine fitting just as shown in the photo. As a further complication, the brass fitting was purchased at WalMart and listed as for "Use with Yamaha brand motors."
Anyways, my basic question is: does the attached photo represent a normal fuel hose to engine connection and will it function without leaking? If I have the wrong connector, what one do I want (there don't seem to be any in the stores I have been in that are listed for 1982 Mariners)?
