Do I have trim/tilt? (Really new to this)
MichiBoater
OK guys I admit I'm very new to all of this. I bought the boat with the motor and trailer really cheap and I'm about to have an awesome summer cruiser with my family (I think). I spent all winter building new seats, cleaning, new carpeting, etc. But the motor has me baffled.
From the S/N it's a 1977 Mercury 850 Thunderbolt. I have the Mercury original maintenance manual. It tells me that the S/N would say PT if it had power tilt but it doesn't. It's just a serial number with no letters. BUT... there was a toggle switch (very aftermarket looking) near the steering wheel that said up and down with 3 wires going to it. The wires go to a little cube with more wires, which I think is just fuses. That's near the transom (not part of the motor at all).
The motor has two "shock aborbers" and when I picked up the boat the motor was "up" on a metal stabilizer pole attached to the trailer, presumably to save the transom when trailering. There is a lot of what looks like grease caking down the side of the motor, below the engine, running down the side of the engine on the "front" --nearest the transom/boat. I kind of thought that might be hydraulic fluid for some sort of tilt/trim but honestly it doesn't look like there are any hydraulic fittings anywhere on the "shock absorbers" and it doesn't look like anything in the manual in the tilt/trim section, although the manual *does* cover more than just this engine.
SO... I am clueless! I admit it! I can lift up the engine (working against the pistons/shock absorbers, I guess, because it's hard to lift). It pretty much stays up when I do lift it up.
I assume this means I just have to lift it up which is not easy when I'm putting it on the trailer and use the bar to hold it up. Then let it down when I go to the lake for fun in the sun and it just stays down in the only down position it can be in-- against the stop and there is no trim?
I'm attaching photos and hopefully someone can tell me what the heck I have gotten myself into!
Thank you in advance for any experience, knowledge, advice, and thoughts on my super cool new boat! BTW it's a 1975 SeaRay SRV 180 on a Holsclaw tilt trailer and the whole package was a $300 Craigslist special, complete with trashed seats and 3 Hefty bags of squirrel dung and nuts, etc. from its previous forest home. I put new plugs in the engine and new gas and it started right up and peed like a champ with the flusher attached today. This is going to be fun, I hope!
Bob
75TowerOfPower
Re: Do I have trim/tilt? (Really new to this)
Those shocks are to prevent the motor from flying up if you goose it in reverse. You could add T/T to it if you wanted.
MichiBoater
Thanks. I'll be doing in-water testing in the next couple days.
MichiBoater
Does anyone use one of the lever handles that they sell on eBay, etc? It seems like it might be a reasonable way to lift up the motor before going on the trailer. I wish I had $600 to buy a tilt system. All the previous owner apparently left me with is the switch and the relays.
jerryjerry05
Those lift handles do come in handy. The most important thing is to make sure EWVERYTHING is lubed<LOTS!!!!!!.
It looks like it's in need of some right now.
First thing if it's been setting change the impeller.It might work right now but if it's old it's gonna go.J
Silvertip
The motor you have may not have been original to the boat meaning the previous motor had tilt & trim. This one doesn't.
