Do I need a longer shaft?
Philip_G
I know people say the antiventilation plate should be even with the keel, I'm maybe 4" too high.
you can see from the scum line where the water line usually is. I'm getting a weird slipping thing, like the prop is cavitating and revving up
BLU LUNCH
Re: Do I need a longer shaft?
Sure looks like you need the next length shaft. Is the motor mounted all the way down on the transom?
Philip_G
Yep, sure is. The transom isn't much higher than the top of that picture, frustrating. I'll try to post a video of it running on the boat, I've been trying to figure out what is causing the revving, cavitation or a cylinder dropping out or something.
it's a 9.5 and only pushes my 14' boat at 5.6MPH too.
BLU LUNCH
You are cavitating you need the longer shaft.
Home Cookin'
around here, used short shaftsa re hard to find b/c people hang on to them, or buy them quickly.
The sailboats use the long shafts. But in Colorado?
You may be able to buy a seized-up long shaft and swap your top for its bottom.
Also, when rigging it, remember that the "scum line" is irrelevant b/c that area is dry when you are on a plane.
Philip_G
she doesn't get on plane, not enough HP ;)
it's tough to tell from the vid how deep it actually sits in the water, the boat sits really rear heavy with me and a fuel tank back there.
tough to find ANY old kickers around here, I gave way more than I wanted to for the 9.5 out of desperation, I'll use it a few more times and dump it I guess.
Lion hunter
That motor has a 15" shaft, you need a 20" . Sailboats usually use a 25" . What is the HP rating for the boat? I don't think there is any way to modify that motor like the later 9.9's. I would get an adjustable transom bracket and mount the motor off to the side and use it as a kicker until you can get a larger motor. If you get the leg in the water and the boat don't way to much that motor may push to a plane anyway. But it's never gonna be fast.
Edit: I have aslo seen several river sled setups that they notch the transom off to the side where the kicker bracket would normally go so you don't have to deal with lifting the thing up and down. The boats are made with a 5' deep square notch that is reinforced and wide enough to accept the kicker. I'll see if I can find a pic. On further thought this would only work with console steer and not with a tiller.
Fisherball
Your title almost demands a smart*** answer! Let's just say that she (the boat) thought so.
Philip_G
Near as I can tell they made an extension for the 9.5, but finding all the parts would be a nightmare I think.
The boat is rated for 25 or 35 HP I can't remember, some of the lakes around here only allow less than 10hp, I would be happy with about 10mph, which I figured I'd get out of 10hp, guess not!
The darn motor just isn't running right either, it runs OK but smokes a bit too much and likes to die randomly at idle, always starts back up but I lost about $10 in tackle today because it died and I got hung up. But that's another story for another thread.
I'll just use it until I can find a longer shaft motor and buy another and sell this one I guess.
