bsutravis
- Joined
- Jun 11, 2010
- 64
I'm dealing with a '77 Mercury 1150 / 115HP - Ser. Num 4569747
I having an issue where when I go down on the throttle and hit the 2000 RPM range my boat seems to gently ease out of gear and the engine revs. It always happens when the boat is about 1/2 way to plane and when it happens the prop still turns but the RPM's go way up. I can come out of gear and can hear the clutch dog come out of forward gear, then when I put it back into gear there's a nice crisp engage into gear - no grinding noises or anything odd sounding. I checked the L/U oil and there is no metal whatsoever and the oil has no water.
I was hoping it was a spun hub issue, but I marked the hub and took it out to replicate the problem, when I pulled the prob off all my marks were still lined up, so I know it's not the prop. The prop shaft looks great, and like I said there are no odd sounds or vibrations coming from the motor. When the RPM's rev up the boat sort of maintains the current speed, till I back off the throttle and I can leave it in gear at any speed below where it seems to loose the gear and it will maintain that speed... ie, I can "troll" around at say 1500 RPM's with no issues, but when I go to 2000+ RPM is when it seems to slip out and the RPM's start to climb quickly.
Does it sound like my Lower Unit is shot? Do you guys recommend a rebuild or find a used unit? Could it be something with the shift shaft? If I decide to probe inside the L/U what tool is needed to get that initial "nut" off that threads onto the outside of the gearcase?
Thanks for the help.
