Do I Need a Tower or A Pylon?
Bulbash
Trying to learn waterskiing, wondering if deep waterstart would be easier with tower or pylon?
haulnazz15
Re: Do I Need a Tower or A Pylon?
No, correct form is all it takes. Nobody skis off of a tower, and a pylon (properly mounted in the center of the boat) only helps with boat tracking once you are up and are pulling hard outside the wake. What is the size/HP of the boat you are trying to get up behind? Also, what is your height/weight and the size of the skis you are using?
Bulbash
Boat is 17' bayliner capri with I/O 128hp, me: 180cm 95kg. Skis: Airhead wide body 54"
haulnazz15
I'd say your skis are too short. Find a set of 66-68" skis, more length means more surface area to lift you out of the water. A 17' boat with 128HP should be able to pull you out of the water, but it might struggle if you have more than 1-2 people in the boat.
emilsr
You don't need a tower, a pylon or even different skis; all you need is practice.
How long have you been trying?
oldjeep
Just needs more practice, those wide body 54's have as much surface area as a conventional set of 66-68's.
Bulbash
Will be trying again next weekend...
Thank you guys for help
H20Rat
You are going to suck some water doing it, that boat is a little underpowered for that application. As others mentioned, keep the boat as light as possible and get your spotter to hold down the bow for you! Wearing a wetsuit helps, it keeps your clothes from dragging in the water.
Also, some people prefer keeping your back foot out of the binding during a deep start, others have it in. I personally learned with it out, and although I can start with it in, I have to be careful not to plow water on slower starting boats... Its easy to straighten the back leg and turn into an anchor.
haulnazz15
I don't think he's trying to slalom ski just yet.
haulnazz15
I'd agree with you now that I looked up that ski. I just saw the 54" and thought there's no way an adult is getting up behind that boat on that short of a ski. I still don't like the idea of the "widebody" designs simply because it sacrifices a lot to help a bit with one small part of skiing, but I guess whatever works.
emilsr
I used to think that until I tried one of those "Big Daddy" slalom skis. Yes, it turned like crap, but I was much less tired after a deep water start so that helped make up for the turning. It took some getting used to, but it was a more relaxing type of skiing.
I'm too old and fat for tournament type skis these days. :rolleyes:
haulnazz15
Lol, well I haven't had too much trouble getting up on a properly-sized slalom ski so I don't usually wear myself out on them. However, I can understand their use on slalom skis. I don't see them as being needed on combo skis, as it doesn't usually require a lot of effort once you learn to get up on skis. I weigh 230lbs, and run a 69" slalom with double boots, and have never had much issue getting up on a deep start, even behind a 17' boat with a 115 O/B (although it does take much longer than the V8 runabout).
Now, I have struggled to get up behind that 17' boat on a 67" slalom ski from a set of combos. So, my point is that if you have an appropriately-sized ski, it makes a world of difference and usually negates the need for a "wide-body" design.
oldjeep
The benefit of the wide body slalom skis is that you can get away with an awful lot before going over the front ;) As a downhill skier, I've got a bad habit of leaning forward into turns early in the season and on my KD Powercarve I can do that without any problem. On my Obrien Evidence when I do that, bad things happen. So the fat skis are really nice if you just want to get up and survive, if you want to get good then you need to use a conventional ski and learn how to do it right.
For combos it really doesn't matter that much. We've got a pair of each - standard 68's and a set of the short fat things. The only time I ever use them is when I'm bringing a kid up and to be honest neither one of them is easier than the other. I suspect that the short chubby ones are easier for a beginner since they are less likely to want to float different directions while you are ready to get up.
H20Rat
In that same vein, the widebody skis are much slower crossing the wake. I ski on both, but when I go back to my narrow slaloms, I end pulling too hard and picking up way more speed than my ability allows for!
