Boat is 17' bayliner capri with I/O 128hp, me: 180cm 95kg. Skis: Airhead wide body 54"
I'd say your skis are too short. Find a set of 66-68" skis, more length means more surface area to lift you out of the water. A 17' boat with 128HP should be able to pull you out of the water, but it might struggle if you have more than 1-2 people in the boat.
Just needs more practice, those wide body 54's have as much surface area as a conventional set of 66-68's.
Two days..
Also, some people prefer keeping your back foot out of the binding during a deep start, others have it in. I personally learned with it out, and although I can start with it in, I have to be careful not to plow water on slower starting boats... Its easy to straighten the back leg and turn into an anchor.
I'd agree with you now that I looked up that ski. I just saw the 54" and thought there's no way an adult is getting up behind that boat on that short of a ski. I still don't like the idea of the "widebody" designs simply because it sacrifices a lot to help a bit with one small part of skiing, but I guess whatever works.
The benefit of the wide body slalom skis is that you can get away with an awful lot before going over the frontAs a downhill skier, I've got a bad habit of leaning forward into turns early in the season and on my KD Powercarve I can do that without any problem. On my Obrien Evidence when I do that, bad things happen. So the fat skis are really nice if you just want to get up and survive, if you want to get good then you need to use a conventional ski and learn how to do it right.
I don't think he's trying to slalom ski just yet.
