FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Just switched props and new 4 blade was hitting the anode so I took it off. I have power steering, freshwater only, and trailered every night. Do I even need one?
You need the zinc sacrificial anode trim tab for corrosion even if you don't need it to trim the motor for torque steer. Grind off just enough to clear your prop and re-install it. No problem, no big deal. Good Luck!
as mentioned you can grind off ( with a mask, or cut with Hack Saw, Or purchase a FLAT Tab and they make Performance Tabs that are set a little more aft of the prop.
