Re: Do I Pack Seals With Grease?
You are supposed to pack grease inbetween seals(prop shaft seal has 2 seals facing opposite directions. One way seals oil in and the other water out. Same with the input shaft seal.) I used NBU-5 grease on mine. It's highly resistant to petroleum products as well as water. I have no idea where to find it locally. I get it from work. be sure to lube your o-rings very well. I believe the manual says to use GSC compund on the gaskets and o-rings.
