mschmidt33
- Joined
- Sep 7, 2010
- 110
Re: Do I want a VSR, Isolator, ACR, or Switch... Help Please.
OK, seems fairly straight forward. Thanks again. I will crank up the amp, start the trolling motor, and crack a beer with the boat in the garage until I drain the house battery like I would on the water, then test after plugging in the charger.
What I would do is do an experiment where you run down your deep discharge to 12.0V which is the 50% point and then plug in the charger. Monitor the voltage at the starter battery when the ACR clicks in and if the voltage on the start battery never dips below 12.6V, you are fine. If it goes below that, you may want to have a way to keep them isolated when you know the one battery is very discharged.
