Do marine batteries NEED to be in a plastic box??
corey4631
I have a kind of stupid and odd question.
I have a 99 Bayliner with a 4.3L V6 in it. I want to parallel two batteries together, which I understand.
My question however is, the compartment that holds the battery is just big enough to hold both batteries with literally NO wiggle room. The batteries are NOT in plastic cases. Do the batteries NEED to be in the plastic cases?? I understand the point of having them in there to not get wet, but this compartment is totally dry to begin with.
LippCJ7
Re: Do marine batteries NEED to be in a plastic box??
no they don't, the purpose of the plastic boxes is to contain battery acid that spills out of batteries causing further damage, there are ways to combat spills other then boxes like regular maintenance and dry or gel cell batteries, I don't have battery boxes on either of my batteries but I must warn you to take good care of the batteries, lack of maintenance can make a mess of things
shrew
corey4631
Thanks for the info!!! I pretty much just placed the batteries in together, strapped them down and then ran them parallel.
Texasmark
The newer style sealed batteries and a properly functioning alternator should not produce any spillover hence no need for containment.........but things can go astray.
Mark
