Re: does a 25 hp need to be drilled
Sixers,<br /><br />Good move getting it bolted on. Now you need to make sure it is done right.<br /><br />Have a nice discussion with your dealer about how they plan on mounting the motor. You want to ensure that:<br /><br />1) Stainless steel bolts are to be used (will not rust). Expect to pay more. They sell for about $10 for a 1/2x6 bolt, lock nut, and washers at the home centers. Figure about $40 for a set of 4.<br /><br />2) The holes and bolts are sealed against water intrusion. They should be using something like Boatlife or 3M 4200 sealer. I don't like 3M 5200 because it is really an adhesive and you may not get the motor off if you need to. And silicone is for bathrooms.<br /><br /><br />The bolt holes are notorious for letting water into the transom core and starting wood rot. It is really worth the time, effort and money to make sure that the transom doesn't start rotting the next time you put it in the water. <br /><br />Good luck,<br /><br />Mark.
