kfa4303
Banned
- Joined
- Sep 17, 2010
- 6,094
Re: Does a hydrofoil improve performance in small outboard application?
Hi Jerry. Have you tried to just clamp your motor a few inches higher up on the stock transom. The underside of the transom bracket on the motor doesn't actually have to rest on the transom itself. As long as the clamping bolts are tightened down sufficiently and the motor is secured with a safety chain, you can easily gain 1"-2" without having to get a jackplate, or tabs. However, if you should find that you still need to raise the motor a little more, you can always make a small transom riser out of aluminum angle and some scrap lumber, both of which are readily available at any lowes/HD for under $20. There lots of DIY versions of transom risers here in the forums if you do a search. Best of fall you can use any leftover aluminum angle to make some fixed "dumb" tabs like in the pic below. They aren't adjustable, but they can still aid in stern lift. Here's a great link.
microskiff.com - Gheenoe Upgrades
Simple bolt-on transom riser:
Here's a shot of my motor on my homemade riser:
Seems I was lost in the "woods" or "water" from the beginning... so tell me how I adjust the outboard up/down relative to how it clamps on to the transom. Such an adjustment has completely escaped my eye and my reading of owner manuals (which I do a poor job of at best). Perhaps my pic 2 in post 32 shows where the vertical adjustment is. The 4 hole choices for the angle of the engine relative to the mount does very little in raising the screw.
