Does all bravo 111 have 2 props?
Dunnville
The boat I just picked up originally had a bravo 1 on it but the last owner had a bravo 111 installed but it only has a signal prop, is this right?
tpenfield
Re: Does all bravo 111 have 2 props?
No, not right. Bravo 3 is a dual prop
Bravo 1 and 2 are single prop . . . Got a picture to post?
Dunnville
Hope this works
tpenfield
Probably originally it was a Bravo 3. . . but I suspect that a Bravo 1 lower unit was put on during a rebuild, rather than a Bravo 3. The upper units are interchangeable.
You do not have a Bravo 3.
Dunnville
Ok thanks, the upper says bravo111 and the lower unit looks new compared to the upper if that made sense...lol
tpenfield
Yup, often you see a bravo 1 lower unit put on when needing a rebuild or replacement, due to the huge cost of the bravo 3 . . . Not that the bravo 1 is inexpensive either.
