does anyone have the p/n for the fuel line from filter to carb 260 mercruiser engine
lime4x4
I'm looking for the fuel line from the water seperator to carb. I'm working on 1986 260 mercruiser engine with a 4bbl carb. Every where i've looked they only show the fuel line from fuel pump to carb. I need the fuel line that comes from the water seperator that's located in front of the fuel pump to carb.
achris
More fish than mountain goat
Re: does anyone have the p/n for the fuel line from filter to carb 260 mercruiser eng
i'm looking for the fuel line from the water seperator to carb. I'm working on 1986 260 mercruiser engine with a 4bbl carb. Every where i've looked they only show the fuel line from fuel pump to carb. I need the fuel line that comes from the water seperator that's located in front of the fuel pump to carb.
Line from water speerator filter to pump.. 32-96083A1
Line from pump to Carb...32-96081A1
tfret
I damaged mine when replacing the carb. I twisted it while disconnecting it from the carb. I simply replaced it with fuel line hose and some brass fittings from the local automotive parts shop. I haven't had any problems, and I even added an additional in line fuel filter, the type you can see through. You may want to consider that unless you just really want to keep it stock.
cr2k
Just need to use A1 fuel hose to keep it USCG Legal.
6meter
I don't think that plastic see-through inline filters are USCG approved. I thought they had to be metal. I could be wrong.
Ayuh,... Shouldn't be there, regardles what it's made of...
That's what the spin-on cannister filter is for.....
wmschenck
Those see thu glass fuel filters are very prone to leaking and could cause a serious fire hazard. Coast Guard will fine you if they do an vessel inspection.
