Does anyone know what max hp is
jayg0351
I have a 1972 14ft Aluminum Starcraft with a 9.9hp motor. This motor does not push the boat very good. I would like to know if anyone knows the max horse power might be for this boat. There is no plate on the boat to refrence.
Chris1956
Honorary Supreme Mariner
Re: Does anyone know what max hp is
Jay, If you match the boat's length and width to a newer model with a capacity plate, you should get a good idea. I'l bet it is between 15-25 HP.
jayg0351
that helps alot. I think I will go with a 15hp motor. I will need to sell my 9.9 first. Thanks for the help
steelespike
While a 15 surely will do better than the 9.9.The 9.9 should be able to do 19 or 20 mph with careful weight distribution and a light load.If you rig or buy tiller extension so you can sit on the middle seat that would help.
Also if you raise the motor vertically 1/4 inch at a time till just before ventilation becomes a problem you may pick up some speed.Just be sure it pumps water.
tashasdaddy
this is a 1960 14' lonestar w/ 1955 15hp evinrude. center seat controls, and stick steering. with me alone, it was one of the most fun boats i ever owned. right at 30mph. just a lot of fun to run around in. wasn't afraid of rough water. sorry i sold it. offer i couldn't refuse.
http://i46.photobucket.com/albums/f119/tashasdaddy/MVC-905S-1.jpg
Bob_VT
I have an old 14' starcraft and the rating plate is for 20hp.
My 18 pushes it w/o any problem and it's a 1967. The older outboards were rated for hp at the powerhead and the newer ones are rated at the prop. A new model 18hp would probably be even faster.
