sam am I
Thread starter- Joined
- Jun 26, 2013
- 2,169
Preface......I have a manual(V6,92 newer 135-225, carb), so I have somewhat of an idea and can interpolate/speculate with the best of them all day
However, Merc. never(I can't find it) comes out and says per-se, other than the fuel pump spec's(moot point), which I saw/have.....
So, has anyone ever MEASURED [or know first hand.....just the cold hard facts Ma'am,(V6,92 newer 135-225, carb)] "A" and "B" with a pressure gauge? [standard relative to atmosphere type (electronic or analog)]
And If so, do you know the values at idle and/or WOT for example? Min and Max values if you will.
Bonus question......Dynamically, there is "pulsing"(shaft rate) superimposed on those static levels above. Do you know the peak to peak(or peak) readings?
Background.......I will be instrumenting these area's and just need a good baseline to design from for the test setup.......There's no conspiracy at hand or foot.
View attachment my_image.pdf
