Does Marinetex 'Shine up' like Gel Coat?
luckyinkentucky
I was wondering if Marinetex will shine up like a gel coat finish. The reason I ask is that I have regrets about installing the access port in the bow of my boat when I replaced my bow eye. A 6" deck plate just takes up too much room on that already small area.
The bow eye is now solid as a rock with 16 layers of fiberglass covering the inner hull, 1/2" steel plate that measures 4" X 6", and double lock nuts holding the bow eye on that I sealed with 1/2 tube of 3M 5200 Marine Adhesive Sealant. I have no worries that it will ever give me a problem again. :)
I was thinking of installing 3 - 1/2" X 1" slats adhered to the existing plywood under the front with liquid nails or something like that. Then, I would fill the area in with 1 piece of 1" plywood cut to the size of the hole, and then lay down 3 layers of fiberglass over that. The final step would be to fill in with Marinetex if it is indeed what I need. Also, If I needed to fill in with MT, and then lay over a small film of gel coat I could do that too.
The area is not visible because it is covered by the rubber mat that covers the nose of the bow. The only thing is that I would know it was there even though no one else would, and I'm a perfectionist, so I need to do it right the first time.
Any suggestions?
ondarvr
Re: Does Marinetex 'Shine up' like Gel Coat?
It will get somewhat glossy, but epoxy doesn't hold up to UV rays very well, so if it's exposed it will lose it's gloss and become dull.
Steve Mahler
I have used it a lot in small spots, and I would say it is quite dull, and needs to be finished for protection.
