Re: Does Pourable Foam Seal Plywood?
I have a question/observation that I would like input on. If using pourable foam under a plywood deck, does the plywood need sealed (CSM/resin) on the bottom? I can see the benefit if under the deck was an open space, but doesn't the foam end up acting like a sealer when it sticks to the plywood? It seems that the only way the plywood would get wet is if the foam was compromised and therefore the deck and foam would need replaced. I am assuming that the top of the plywood would be completely covered/sealed with CSM. Thanks for any input.
IF:
1. your below deck is poured solid with foam, and:
2. your hull is watertight, and:
3. your deck is completely sealed and watertight, and:
4. You keep your boat covered and dry when not in use:
... you have nothing to worry about by not sealing the bottom of your decking, and might even be considered a waste of money if you do seal it.
A watertight hull filled with foam will be impervious to water, and should your hull be breached the foam will seal off the hull preventing water from entering.
A well glassed in deck top with
NO PENETRATIONS and a water shedding finish like
GEL COAT or any other finish that aids in the draining of water (unlike carpet the absorbs and retains water) will/should keep you decking and below deck structure bone dry.
Just remember, the first time you put a screw through your completely sealed new decking... you might as well have shot your boat through the heart with a .44 magnum.:mad-new:
... and laying carpeting in your boat is like strapping a suicide vest to it with a delayed timer on it.:facepalm:
