Does slow mode cut out cylinders 1,3,5
Newportme
I was just reading another post and it got me thinking I all of the sudden lost spark on cyl.1,3,5 could it be going into slow without the alarm?<br />I have not gone through the full manual ignition check yet and if I could eliminate something else it may save time. And at this time of year in Maine i'll need all the time I can get, before too long i'll be ice fishing. :eek:
Newportme
Re: Does slow mode cut out cylinders 1,3,5
Sory evinrude e225cxcce
Walker
The shift interrupt switch will cut out 1,3 and 5
Walker
Oh, sorry, I see you've already tested it. This is why you need to stick to one thread.
Newportme
Yeah Walker I was grasping at straws trying to stumble onto an easy fix ( I should know better) I didnt want to append the old thread with another question in a different direction thats why I started this one. I will direct all testing results to the old thread. I'm kind of new to this forum and the unwritten rules are a little different at each one. This forum has a great deal of information and hopefully someday i'll have something to contribute. thanks again
Walker
Okay, does your motor have 1 or 2 power packs??<br />If2 then swap them and see if the problem switches sides with the power pack. If you only have one then test the charge coils on the stator.
Newportme
Walker thanks I am goint to run the checks from the manual this weekend, I believe the first one is the charge coils. I have only one power pack. Thanks again
