Sorry for this being a bit wordy. But I always thought that vapor lock was something tossed out when there was seemingly no easy explanation for an engine to stall. Perhaps it is real?
Here's what happened...
Launch the boat and cruise 35 minutes (or so) across the lake loaded with stuff to spend the weekend. Unload, set up the tents (took about an hour), then head back out to join others on the lake. By this time the outside temp has climbed to 111 in the shade. We sit for at least an hour enjoying everyone's company, then push off to do some skiing. I only went about 200 feet out before the engine suddenly dies and refused to start.
And what I did...
Could see something squirting in the carb, presumed it was gas. Pulled the #1 spark plug and saw spark. I get towed in and let the boat sit until the next day and try again when everything has cooled down. But still no go. The engine cranked, but does not fire at all. I removed the fuel filter and notice it is half full. I did not try starting it until I could get a second opinion. He can see/smell gas squirting into the carburetor. I again try cranking it over and it fires right up and runs like a champ.
Boat specifics...
1994 Wellcraft Excel, Volvo Penta 4.3L V6 2 bbl carb
replaced: anti-siphon valve (2002) fuel pump (2004) coil (2005) filters (every season)
Questions?
1. How common is vapor lock?
2. Why only me and not the other boaters I was with?
3. Could this have been prevented?
4. Is there a quick fix once this happens?
And what I did...
Boat specifics...
Questions?
