Kevin70
- Joined
- May 24, 2006
- 342
AQ125A/270<br />I removed 6 bolts total. I CAN NOT get this thing off. There could be one of two problems.<br /><br />1) Just above the two starter bolts, there is another hole with no threads inside. In this hole I can see a plug of metal. Same goes for the other side. Could these plugs be holding this thing that solid.<br />2) The u-joint shaft that goes into the bellhousing is frozen in there. I was taking the bell off for that reason. Could this shaft be holding the bellhousing on.<br /><br />Thank you in advance for your time.
