Done Sanding, ready for primer.
epresutti
Folks,<br /><br />Finally done sanding, got rid of all spider cracks, scratches, gouges, filled holes, bottom paint, etc. should be painting next weekend, will be using Interlux perfection. Here is the latest. Boat looks wet, because it is, just finished scrubbing it.<br /><br />
<br />
<br />
<br /><br />Thanks for all of your help and encouragement.<br /><br /> Whole project. <br /><br />Peace.<br /><br />Ed.
Boomyal
Re: Done Sanding, ready for primer.
I still see too much gloss on that hull Ed. That is bad for paint. Or maybe it's just the picture.
epresutti
Boomyal,<br /><br />Boat is wet, just washed it before I took the picture. I will be double checking for gloss, entire hull sanded with 120 after 60 grit.<br /><br />I will be double checking though, thanks much.<br /><br />Peace.<br /><br />Ed.
Tom Scully
Thanks for the update, I have been following your restoration for some time. I will be restoring a boat soon and will put the info you have posted over the years to good use.<br /><br />Thanks again and good luck.
