doo something
armenk35
i have a 1987 force 125 outboard. i need the tilt and trim system cheap if possible. can anyone tell me where i can find one cheap or if anyone has it plz tell me. i live in la and can pick up from a 100 miles range. thank you
Tim Wagner
Re: doo something
E-bay first.
Another thing is whats wrong with it?
maybe your brushes wore to a nub?
They can be had pretty easily.
Not hard to fix if you know soldering techniques.
armenk35
Re: doo something
i broke the hose bolt from the shock and my motor is licking oil from the hose inputs
Tim Wagner
Re: doo something
When you say hose bolt. Do you mean the fitting??
If thats the case, then they make a thing called an EZ-OUT.
Since there is already a hole in the broken fitting you dont need to drill.
There are different sizes of course, but it has a reverse thread on it.
So as you screw it in the existing hole, in reverse to remove the piece, it gets tighter and eventually in a perfect world, knocks the threads loose and wa-la, you're back in business after a trip to home depot for a new fitting for the piston and a compression fitting to join the two pieces of tubing back together.
